cams, lifters, rockers
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
Solid Axle Swap
Plattsburgh, NY
1999
hey guys i just got done rebuilding my 4.0 with a new com cam 410 cam, rings, bearings seals new 5.5 smith brother push rods. i have a clatter when i start it up and it kinds diminishes a little when it warms up iam thinking it was lifter tick. i just took my motor back out and tore it down and took a look at the lifters. they all seem good and none of them are stuck. i did noticed that since the smith brother push rods were fatter one was barely rubbing the side of the new aftermarket head. after doing some research, i still wasn't able to answer my question.. will the Delta Cam Rocker assembles Work with Stock lifters, 410 comp cam and 5.5 Smith brother push rods? i believe my noise is coming from the rocker assembly from what i have read. iam still using the original one that had 160k on it.
__________________
well i ended up ordering the delta cam rocker assembly and push rods... and can some one answer this question. can i use the comp cam 410 with the delta rocker assembly and delta push rods or do i have the use the smith brother push rods???
