Camper/pop up questions
We have a pop-up from 1973 that I rebuilt. It does its job and everything but setup/takedown is kind of a drag sometimes. After driving 8+ hours it's nice to have something mostly ready, just unhook and level. Even though the newer ones are easier and faster to set up I'd consider a travel trailer, especially if it's just two people and a dog. My parents were looking at an Aliner. It's kind of like a popup but the roof is two solid pieces. They open up to form an 'A' for the roof. This looks slick but they are expensive and lacking ceiling room due to the shape. Cost ended up steering them toward a small travel trailer but then Mom got cancer and the whole thing kind of fell through.
There is a smaller fifth-wheel trailer called a Scamp. It was basically a top and bottom FRP shell fused together. I've seen them towed by Tacomas and the like, so a Ranger should be able to do it. I'm not sure if they're made any more.
Scamps are still made, they'll set up back price tag in $25ks range I believe, and if you order one now, your delivery date would be about this time next year. There's one here in Calgary that follows a Ranger - he doesn't seem to have any issues towing it. https://www.scamptrailers.com/showroom/19-deluxe-trailer From their FAQs: The 19ft (their 5th wheel) was originally designed for the Ford Ranger
Aliner also makes hard sided pop up trailers.
Some more thoughts on it.
A slide in is kinda nice in that you don't have to deal with a trailer. Or you can if you want to, if you play it right you can pull a trailer too. Just like everything else it is all about trade-offs.
Canvas side pop-up slide in
Lighter
Lower clearance (easier to fit in a garage/shed)
Neat openess with the top windows open
Catches less wind for both mpg and handling with a crosswind
Lift mechanisms can be light duty (operate carefully, don't put a bunch of crap on the roof for it to lift etc)
Roof structure sees substantial stress from lift mechanism (more of an issue with age)
Still tall enough to be a pain to store inside
Harder to install in a lifted truck (I have to let the air out of my 31's)
Less secure in theory for bear country (if a park has a problem bear they will boot softside campers until they get it resolved)
Door is short (but it works better than you think it will)
Careful with the canvas/plastic windows!
Can get dew inside like a tent
Hardside slide in
No lift mechanism or canvas to worry about
GTG during "hardside only" camping proclamations at national parks due to bear problems so you won't get booted for being a soft sided camper (keep in mind it is still toothpick and tinfoil construction for real world bear security... don't leave your bacon grease on the stove when you go fishin')
No moisture weirdness associated with a tent
Better in cold
Easier to mount things on the roof (aka canoes etc)
Probably quieter inside (coyotes, wind etc)
Generally have closer to a full size door
Catches more wind on the road, both for mpg and crosswind/handling
Heavier
Even worse clearance than a pop-up slide in for drive thrus, garages/sheds
Prices vary wildly, out west like California or Colorado they can be pretty pricey with the current "overlanding" fad in full swing. In the midwest... everybody goes for a fifth wheel to drag 5 miles to the local state park and/or the state fair so the market is more limited both to buy and sell. They do make hardside popups... I haven't really looked into them.
Now if you meant a popup trailer...
Neat open view
Lightweight... Someone makes one you could pull with whatever you have (does not require a truck with a bed between this long and that long that it is no more than this deep with a cab that can't be taller than this...)
Easy to park/store inside
More tires to maintain
Another license plate (some states require slide ins to be registered)
Trailer to insure (again some states/insurance companies consider a slide in a separate thing)
Trailer "fun" for maneuverability
Like 0 real security (at least with a pop-up slide in the canvas is 6-7' off the ground)
And you get a lift mechanism of sorts to take care of
Just my $.02.
Aliner makes hard sided pop up campers of all kinds of sizes and tow weights too. Like you said, each option has it's pluses and minuses.
Perhaps a roof top tent might be an option too. They have soft shell and hard shell options with those as well. Of course, then one has to consider what their roof rack can handle if they plan on off roading...
Pick your poison I guess.
Any excuse to post a pic from last years trail ride...
57078
