Woods-Rider
I noticed i had some negative camber a little while ago and couldn't figure out the problem since it was adjusted all the way positive. I had my truck in the shop on Monday to have some gears installed and while it was in there i had them take a look at it. they said it was bad inner tie rod ends and bearing hub. I tore it apart and found them to be bad so i spent the next day and a half making trips back and forth to Napa replacing both inners and one outer that was bad and the bad bearing hub. i took it in for an alignment when i was done. they said since my torsion bars were cranked they couldn't get rid of my camber issue. i took it home lowered the front via torsion twist and took it back just to have them tell me they still couldn't align it properly. what else could it be? i have a 4" Superlift and 3" body lift and am running 35's. heres a pic of how bad it is.
