Camber bushings
shadow88
CLOQUET MN
So I've decided that I'm going to do a 2" lift in my B2, I'm going with 2" leveling coils up front and explorer leafs in back, my question is should I plan on getting adjustable camber bushings? Or should they be able to align it without them? I've done a search on this but most of the threads have been on rangers older than my B2, thanks for any info!
i would let the good alinement shop pick them out if you need them. with out digree option that you do not know that you need. it could get pricey. i would free them up so the shop does not charge you more. but this is from my own experience.
If you buy fully adjustable units from NAPA, they're $36 per side and you shouldn't have to worry about it again. You're definitely going to need to adjust them for the lift.
