fishinsam
- Feb 21, 2013
- Automatic
Hi all, im new to this forum and joined because of some problems i've been having and would like to fix. one of them is a camber issue. i bought the truck used just over a year ago and it seems like a lot of home work has been done to it. i know it has drop brackets for both driver and passenger side and lift springs, although im not sure what size. When i took it to the tire shop, they wanted $280 to fix my camber issue. im hoping i could buy and install the part and have the tire shop fine tune them. i understand i need a new caster bushing or shim my spring with washing to fix my camber issue. it has a -1.6 degree right front camber, a 6.1 degree right caster, and .14 degree right toe. for the left it has -.8 degree camber, 5.8 degree caster, and a .14 degree toe. i'd really appricate some help on what bushing i need to buy and how to best fix my problem. the inside of my tires are heavily worn and the outside is barely touched. thanks in advance, i've already gotten tons of help from this forum.
