tllwisiorek
- Sep 15, 2012
- Automatic
Hello I need help. I am replacing the ball joints on my 1988 Bronco II and on my upper ball joint there is a camber adjuster above the nut on the shaft of the ball joint under the spindle. How do I remove it? It has a channel in it and teeth as if a twelve point socket can be used to remove it. If so can u tell me what size to use? hank you Terry
