Broosedamoose
DaMoose is lose!
- Mar 10, 2012
- 4.0 V6
- Automatic
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
I've read a lot of thread on here about this but can't find my specific answer. Lot of good information! I ordered a rebuilt short block (1978-2000) and it came with a 270/286 camshaft. They couldn't give me any details on who the manufacturer of the cam is or it's performance data, only that it's a "muscle" cam. I ran a search and all I can find is mostly Comp Cams Marine cams. So I think I want to replace it with one that will better suit the engine and my driving style. The short block came bored 30 over with flat top hyperutectic pistons and hardened rods. I have a set of aluminum GT40 heads that have been ported and polished with 1.7 roller rockers. The intake is a TricFlow Trac-Heat with a 1"spacer (needed to clear the injectors). Using a TricFlow 75mm throtlebody and the stock MAf sensor. My truck is 4wd but I rarely use it in those conditions. I used the Advanced Adapters set up so it's true 4wd and not AWD. I did the Explorer rear axle swap and used a Ford Performance TracLoc with 4:10 gears. My driving style is, get from this light to the next as fast as possible and get on the freeway at the speed limit (or just above). In other words, I like to go 0-60 as fast as possible. So my question is, do you think the 270/286 cam is ok or do I need something different, and what do you recommend? Thank you!
