YungICY
- Jul 19, 2013
Hey guys and gals. I'm thinking about changing the cam in my 2.3 because I went with a comp cams magnum 280h and it isn't a good fit for a daily driver vehicle (doesn't much like anything under 3k rpms). I think I'm going to change it out for the comp cams high energy 260h which is more of a daily driver torque increasing cam.
The 280h has a valve lift of .460 and I have dual rate valve springs that are suitable for that amount of lift.
The 260h have a valve lift of .420. Will I need to install new valve springs or will the current ones work fine?
I assume the current ones will be fine but I thought I'd double confirm since engine building isn't exactly my fortè.
