at 140k miles I've got a lifter on its way out. who makes cam and lifter kits for the 3.0? I'd like a cam to open it up a bit. I've got a k&n with a flowmaster exhaust, and I opened up/polished my MAF.
Tell me about it. I just got an e-mail back yesterday from Camcraft regarding a cam for my 2.3. Here it is:
at ~200 bucks a pop there a bit pricey though.
if your so dissatisfied with the motor than why are you putting money into it?
I know my post was pretty general, if I found a place that stocked 3.0 cams I'd call them and give them the specifics I needed.
mtnrgr-yes, the 3.0 IS A TURD. I'm glad you are satisfied with its less than adequate performance though. I dunno how many miles you've got on yours but it sounds like you've done quite a bit of work yourself to keep it alive. its a shame there's not a bigger aftermarket for "one of the best engines that Ford has ever produced." I'm sure there's some diehard 5.0 fans that would drive that statement into the ground but I won't go there
pete-I understand I'm going to have to do some asking around now. I'm curious though, what does the tire size, rear end ratio, transmission ratios, etc. have to do with a cams ability to increase/flatten torque/HP curves?
Bray,
Go there is you want I don't care. 5.0 engines being put into rangers are more then a dime a dozen. That means alot of people have done this across the country. This is my truck that is used everyday so putting a v8 in there is something that I did not want to do, did not want that much weight in the ranger's front end. This has been discussed already in the past with friends and others, I chose to stay with my 3.0 & build it. Not to many people can say that they kept thier 3.0 & tore it down to rebuild like this. Yes, I do have alot of time & money in doing this to my 3.0 & I am very satisfied with this little monster. I have had this ranger since new, It has & will do anything that I give it. I know the 5.0 is a good engine, the 3.0 is still a good engine, don't want to pay the gas prices of a v8. If I want a 5.0 I'll buy a mustang.
I don't give a shit about the DIEHARD 5.0 fans, I run what I run. Just because you are not happy with yours does not mean that others have issues like you. Mine had 260,000 before the teardown, now it has over 70,000 & going strong.
