Justin's Green Truck
- Feb 14, 2010
Hi, I have a 1997 Ford Ranger 4.0l 4x4. The truck was rolled so the cab needed to be changed. I found a cab from a 1993 ranger with a 2.3l and 2wd and have installed it on the chassis. I am going to use the dash out of the 93 because my 97 wont bolt up to the firewall I found out. This, and the way the ECU mounts on my 97 have brought up some challenges.
1. The 97 ECU mounted on the upper firewall near the wipers. The 93 cab that I have mounts down near the left kick panel.
2. The body harness going into the cab is different.
3. The cab i bought was a 2wd so il have to plug in my transfer case harness to the rest of the wiring somehow.
My questions are: Could I find an engine wiring harness from a 93 4.0l and would it have the ECU that mounts in the kick panel? Would this 93 engine harness plug into my existing body harness?
I realize what I should have done was put a 97 cab back on it but I thought they were all the same at the time.
Now im just trying to get everything working if I can. I think I should just go to a junk yard and find a 93 4x4 with a 4.0l and get all the wiring off of it. That sounds like the only option to me but if anyone has some info id appreciate it.
