cab swap
lifted ranger
Ok so I have an 87 ranger 4x4 frame is in great condition but the body is done for so can I swap a 94 Mazda b2300 cab
and bed on to this 87 4x4 frame?
94 cab to 87 frame should work fine...may need to cut some holes for shifters if needed but as long as you are swapping regular cab to regular cab frame or extended cab to extended cab frame the mounts should line up...
I just swapped an 88 cab onto a 96 frame...both extended cab...lined up perfectly...
