Dan R
What is the purpose of the washer with the cross shaped hole that sits on top of the front, #1 cab mounts?
I am in the middle of replaced rotted rubber bushings with poly ones.
Tip. You will need an impact wrench to undo the bolts. And several goes at unscrewing and screwing back up before that bolt comes out!
Bolt has a 15mm head.
