I patched mine many years ago but can't remember what I used...I can see body filler though and I don't think the hole I patched was very big...at the time...
I also just saw somewhere that they actually sell cab corners for Rangers...might have been LMC...so depending on how bad your corner(s) is/are...that is an option...
The 3M site has some guidelines for what is just panel bonding and kosher to use their product on, and what is structural (eg: rockers) and should be welded:
http://3mcollision.com/3m-panel-bonding-adhesive-08115.html
News to me. I thought, at least here in Saskatchewan, everything had to be welded to be acceptable for body integrity inspections. Someday I have do some wheel arches, and something like this would be awfully nice to be able to apply.
Any insights out there?
Update: taking a quick gander around the net, the general consensus seems to be the panel adhesives work pretty good for sticking on whole panels (quarters, bedsides) where the seam is either acceptable or can be hidden eg under a moulding. Also, some of the newer vehicles out there have pretty thin tin that can be tricky to stitch weld w/o warping.
For patch panels w/ overlap eg:cab corners, wheel arches, differential expansion will eventually make the repair seam visible.
