c4 will NOT change gears with shifter...
l0sts0ul
Edmonton, AB, Canada
HEy guys,
Finally got my 347 fired up and broken in, in my project 94 ranger, but this is where it gets wierd.
I was checking my total timing tonight, and luckily for me, I have all 4 wheels in the air.
I heard a snap, and next thing I know, the back wheels are spinning.
tried shifting into neutral, reverse, park, anything other than drive... nothing... I got underneath, and no matter what position I have the linkage in, I can still turn the driveshaft.
What would I have broken. This is a freshly rebuilt C4 strapped to a 347.
Please give me some clues here, I was thinking about dropping the pan and the valve body... but what do you think?
thanks
Sounds like maybe the parking pawl inside the transmission broke or came out of position
I dropped the fluid tonight, and found it smelled burnt and was greyish. Found some metal on the plug magnet...
cooked?
So I dropped the pan, and the valve body.
Couldn't find anything that looked out of place, but to be honest, I don't know everything about what im looking at. Nothing looks bent, or broken. the manual valve moves freely, and so does the kickdown on the valve body. I checked the shifter linkage and everything looks ok.
any suggestions as to why this would happen? is it possible the forward pack is seized ?
would anything move if the planetary were screwed? probably not right?
thanks
