rebuilt my C-4 myself,put it in and had a leak between the bell and the case (being a dumb a$$ i forgot to check the pump bolts after i put my newly scored 2800 stall converter in).trans worked great but after leaving a very expensive stripe of B&M trick shift down the road i pulled it and found the loose bolts.
tightened those and thought i had it fixed (another dumb move)put it back in and still leaks.pulled it again today and removed the pump,broken gasket on the return side between the pump and the case.
my question is can i make this out of some gasket material or should i order one?i don't want to pull this f%$#@er again but i need to get this pig on the road.i only have a day or so to do this,off work and great weather as my shop is the great outdoors and it was 70 degrees today and 50 tomm.
i know theres some trans guys out there.............hook me up with your honest opinion.
