wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
- Aug 22, 2012
- Southwestern Idaho
- 2.9 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 215/70-R14
- My credo
- 19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
According to research my 2008 Ford Explorer 4.6L V8 has the BW4411 transfer case. ADSM08 mentioned in another post that the transfer case only uses a magnetic clutch in 4Auto, but uses the typical sliding collar for high and low range. However, after reading online it seems the magnetic clutch controls everything, so who is correct? I'd lean towards ADSM08's explanation but how does this thing work? All I've ever had was manual transfer cases, you pull a lever its in high or low range, except on my Jeep which had Selec-Trac which gave me 2wd, full time, plus high and low but still with a lever and all mechanically operated.
I've played around with the 4WD Auto a bit and its almost an instant very smooth engagement. High and Low feel normal to me for a part time system but are they really mechanically linked in high and low or is that clutch actually the connection between the front and rear axles, and if so how reliable is this?
