bw1350
rngrdngr
SO CAL
Im converting my 99 ranger to 4wd.can i use a bw 1350 transfer case divorce mounted? or is there a good junkyard in the So Cal area that would have a 4r44e 4wd trans and a bw1354 transfer case?
Well you would have to figure out how to get a yoke or flange on the input of the Tcase which is meant to receive a splinded shaft. I am pretty sure you would need a very large machine shop at your disposal to accomplish that. Then you would need to set up the shift linkage assuming you went with a manual. I would just find a 4x4 tranny if I were you.
I don't think you really know what you're asking. No offense.
Find a 4wd trans. It's the best solution.
