bw1350 fluid?
The_Dealer
Macon, GA
what type fluid do i use in my 1350 manul t-case? is it the same as in the tranny? how much do i need?
also i just replace my t/c and most of my fluid came out of the tranny, how much should i buy?
Use Mercon ATF, which is the same stuff you use on the trans. You shouldn't have lost any fluid out of the trans. It sounds like you need to replace the output shaft seal.
i took my tc off, replaced with a 4.0 low stall tc.and took off my t-case and accidentally tipped the tranny sideways and all my fluid some out of the back
the 1350 uses atf, but ford sells something called transfercase fluid that also works, better some say.
