Wanted BW 1350 T case(or an output shaft CT
kmart96
connecticut
Dunno if I can delete these but I was able to get my hands on something that works, appreciate the feedback
Just want to be clear - front or rear output shaft
'cuase the rear output shaft is identical for all BW1350 & 1354 transfer cases more/less.
I need the rear out put shaft. And if that's so that would sure be helpful. But nothing comes up for my search other than the smaller 1356 shaft. I can't say I know much about these but so far everywhere I've looked or the places I've called have said they can't find it. And by more or less? What do you mean
You can use the output shaft (for the rear out put) from ANY 13-50, 13-54, or even the 13-59 “dummy” case.
this should widen your junkyard search quite a bit!
