Buying a Ford Bronco 2
It's kind of hard to say if it's exactly worth $3k. Around here, if the body isn't full of bondo, it would probably be worth it because rust is a serious issue and you don't see many good truck bodies. Add to that, I've never spent more than $340 buying a BII around here because I've always bought stuff that needed a lot of work.
Now if BIIs are not all that common around you and the few that you do see for sale are expensive or junk, then it may be worth investigating. If there's no really serious issues and you're willing to spend that kind of money, then it's worth it. But like I said, a lot of that depends on things like how rusty it is and where the transmission is leaking from along with what those sorts of trucks sell for around you.
I agree. I don't see many, but lately since cruising around on the local bus I have been seeing a lot of 87-88 Rangers, only one Bronco 2 and that was at the court house where I'm from. In obtaining this beauty, what would be an option you would recommend adding to it, to make it better in your eyes?
Make it better in our eyes? It will be your truck...make it look how you want it to look. Not everybody likes the same flavor of icecream, pick your flavor and run with it!
Liftkit and big tires? ...lowrider? ( you are in Cali...lol) Stock? Prostreet with a bigblock?
You decide what you like and go for it, it is you that has to drive it and own it. Make it yours and enjoy the hell out of it!
They are not a collector item (yet) and if any are they are already in a museum somewhere.
From my dealings ...the B2 is the red headed step child to most people. They like them or hate them... Even some die hard Ford guys hate them for some reason.
here is the NADA Book values ( not sure how real world accurate it is) : do you think 3K is worth it?
http://www.nadaguides.com/Classic-Cars/1988/Ford/Bronco-II/2-Door-Utility-4X4/Values
What you do with it is entirely up to you and what you plan on using it for. I had originally purchased my 88 (it was my first BII) with the intention of making it into an off-road toy, but that changed after I got it drivable and found out what an enjoyable vehicle it is. My choptop was my second purchase and since that was already what I was wanting for an off-road truck (the top was already chopped), I decided to convert it to 4x4 and build the street-legal wheeler I wanted. At some point I had toyed with the idea of selling my 88, but when the motor swallowed a couple valves, it wasn't worth selling.
My choptop kept growing. I still see ways that I could lift it even higher, but I think I'm at a good height and that it's capable enough for what I want it for. I actually originally only wanted it on 33's and to be a mild wheeler, but somehow the lift grew and 35's rolled under it. It's fun to drive around, especially in the summer although I have yet to really get to wheel it since I got it completed (drivetrain wise). I always kind of wanted a Jeep CJ/YJ/TJ, but they were always very expensive around here. Instead I built what I wanted out of a BII and I'm happy.
I fixed up and drove a stock 89 BII Eddie Bauer when I was at college. I had pretty much thought of running it as a campus beater and selling it after college. As it was, it turned out to be a perfect truck for running around campus and I even took it to play off-road a number of times. A BII is surprisingly good off-road even in stock form, I managed to impress a number of Jeep guys with it. Sold it towards the end of college for me and used the money to put my choptop on the road. Kinda wish I never would have done that. As fun as the choptop is, it was nice to have a BII to run around in that had usable back seats and an enclosed cargo area. So now I'm working to bring my 88 back to life to have a BII for just general running around.
So it kind of depends on how you plan to use it and what all you want. I put a CB in my trucks because I like having it. My F-150 work truck looks stock to most people who see it, but I have a number of upgrades (heavy springs, ZF-5 transmission out of an F-250, heavy duty brakes, custom snow plow controls, rear locker, etc). I made my improvements based on how I was going to use the truck. The fact that it still looks pretty stock was just a coincidence, I could care less if it looks stock or not, I wanted it to work for my needs.
The father/son project that we put together a few years back was a 2000 Ranger with a fuel-injected 5.0L and AWD. Looked stock, didn't sound stock. We were planning to upgrade the suspension a little and squeeze some taller tires on, but we were building it with the idea of being able to comfortably tow a 24' 5th wheel travel trailer. The fact that it was somewhat of a sleeper was just plain fun.
Is the paint original? Can the 89K be verified? B2s had a 5 digit odometer, so it could be 89, 189000 or ? If its spent its life in Cali rust shouldn't be a problem. Take a good look underneath. If those parts are fairly clean, the sheet metal should be good. The a4ld can be a problem. I know many guys have good luck with them, but in my 8 month search for my current B2 (#3), most with automatics were ready for a rebuild. I bought mine from the original owner in Oct of 2013 and got a grocery bag full of receipts, for every nickle he spent except for gas. Ask the seller if he has receipts for maintenance done by previous owner. Balky power locks and windows are normal. Replace the started solenoid with a Motorcraft, accept no substitutes. Lets us know how your negotiations go.
If going for the stock look, with changing of tires and rims eventually, what should I add to it? Any great "option" off the start.
Ranger STX and I think BII XLS had tube bumpers that looked pretty sharp.
That has kind of been my mission with mine, to make it look period correctly modified. Rollbar, grille guard, sawblade wheels, knobby white letter mud tires...
Thanks! for the price guide. Also to add, I most definitely will make it in the image of how I would like to go about it, but I like ideas to spark of new ideas to form my own. Plus, a heads up on things people have used in the past that I could look forward to adjusting. I've never owned a older truck, such as this 88 Bronco 2. So, any and all suggestions are appreciated :)
Thank you! for your wisdom and consideration. Sam, you mentioned in your comment the "a4ld" what exactly is that? Also, I will gather all receipts from him. It's funny because he new the original owner and the guy who bought it from the original owner and he bought it from him. He is the 3rd owner, but in the same location. He told me he hasn't really needed to do much to it besides replacing interior parts that were missing. If there are some stock things that would be a must to replace, off hand would you know? I know some things are specially designed stock for that vehicle for a reason, but I know some things upgraded do help the function of the vehicle.
A = Automatic
4 = 4 speed
L = Light
D = Duty
Plausible enough, a correctly working one automatically shifts itself through four gears and few will argue the light duty part. Not one of Ford's most durable transmissions.
http://www.therangerstation.com/tech_library/AutoTrans.shtml
http://www.therangerstation.com/tech_library/a4ld.shtml
Tons of info on these things in the "Tech Articles" section
http://www.therangerstation.com/tech_library/index.shtml
A = Automatic
4 = 4 speed
L = Light
D = Duty
Awesome! love finding out new things. Thanks for looking out. Since I'm dealing with a older transmission would it be ideal to replace it? if doing so, would I get a manufactured one of the same model or are there better products of this transmission that will help the life of the vehicle?
If it shifts fine and isn't leaking from the bellhousing, I wouldn't bother replacing the transmission just yet. But I would replace the transmission filter (you have to drop the pan to get to the filter) and add a large aftermarket transmission cooler in front of the radiator. New filter, new fluid, and large additional cooler will go a long way to prolonging the life of the A4LD trans.
Excellent. I was just reading on those cooling systems. Yea, I agree. I do think he has taken really care of this vehicle and wanted it in the best shape he could get it in before showing it to his significant other to drive on a daily basis.
. Also, since these trucks aren't so fast with a 2.9L V6. What could I add to it to give it an extra umph! in it?
If it has 3.45 axle gears, swapping to 3.73 or 4.10 (or to whatever ratio any taller-size tires you plan to put on it call for) will help perk up a 2.9L more than anything else. They make their best power at fairly high RPM, and will still exhibit good MPG too (mine had 3.73 gears and was getting around 26MPG hwy before I lifted it, though it also has a stickshift).
But yeah, do put a decent sized external auxiliary cooler on the A4LD's return line and it should hold up pretty well. Heat seems to be what kills them because the factory cooler setup is garbage.
I will most definitely! keep that in mind. How do I check which gears it has?
The door sticker will specify an axle code, you can look it up in the tech archives on here. That's assuming the axle has never been changed. Another way to verify is to check for a tag on the axle itself and interpret it (that's mentioned in the axle code information in the tech archives too). If all else fails, you'll have to pull the diff cover, but chances are it's the original axle code on the sticker.
Also what's a good size on the lift? I don't want it too lifted, but good enough so it looks snug. Would a 2" or 3" be good? Another thing, how much would it cost to get the gears (3.73) added to the B2?
