Buying a cheap oil pan. Don't want it to rust out.
koda6966
The green part of NY.
Since I'm going to have to pull the engine to do the swap I'd rather not have to do it again a few years down the line. Is there any way that I can paint this to keep it from rusting out?
I was thinking of doing maybe some spray on bed liner, but I might stick with just some rustolium if you think that would work. I dunno.
when i did the pan on my boat i covered it in por-15. but a buddy of mine covered his with rubberized undercoating and it has stayed good for 3 years now
Be careful on "cheap" when it comes to oil pans. I had an engine that had a chrome oil pan and I couldn't keep it leaking from the drain to save my life. Now I only use only real OEM pans, no exceptions. :)
Pete
what you can do is sand the oil pan really good and dont forget to clean it then get some spray primer and and do about 2 coats and then get you some engine paint and put about 3 or 4 coats of that on it and you will be good to go or if you dont have to worry about rust that much just sand it and put about 3 or 4 coats of engine paint on it
I had to make some parts out of steel for my boat trailer (didn't have enough coin for aluminum). What I did was sand the steel down nice and shiny, getting rid of all the rust. Cleaned it up and sprayed it with 2 coats of grey primer. I let that cure for a day and then sprayed on 4 coats of truck bedliner (duplicolor I believe) that you can get in a rattle can at advance auto parts. Parts have held up for 2 years so far after numerous dunking in salt water, no rust spots yet!
