back from the dead, i ended up getting a friend to tack the 760xcaps on a new set of axles...
no problems for months until now, 4 of the tacks failed when my coil popped out, the bumpstop bent and the frame came crashing down on the ttbeam, over flexing wicked and popped 4 of the tack welds on the right outer, i put the coil back in and drove out the trail 4wd, not knowing the tacks had broken, and ended up spinning the caps in the yoke, and now i have another egged out long-shaft from the pass side.
the other joints are still perfectly fine, i took my spare axles and made up a new shaft, ready to be tacked again. need to secure the coil tops now though before i do any highspeed wheelin' (front end leaving the ground)
i have a question though, where are people getting greaseable u-joints? the only ones i can find are $20/each-- which is ridiculous for crappy ujoints, when i can get the strong 760x's for $23 each off ebay.
what i want to do is take some of my old shafts with egged out yokes, install GREASABLE joints, so i can have the caps FULLY welded to the ears, then regrease them--and use them for spare emergency shafts. i know they will not be as strong as the 760x's, but they will be good for spares..
