PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
I have a 1994 2.3, it burns oil at start up, and after it has been sitting at an idle for a while. but not during hard acceleration. I was thinking valve seals, but i put a new head on it less than 3,000 miles ago. It didn't seem to do it before putting the new head on it. I had the intake manifold off recently and was coated with oil inside, and i had already replaced the PCV valve.
I would pull the head and check it but then i have to buy bolts and a head gasket, there is 120 dollars even if that isn't the problem. Is there any way to check the head seals with out removing it? also, why is there so much oil in the intake? the motor has over 150,000 miles on it, it has decent compression that holds, would excessive blow by cause the oil in the intake?
