speedy_fisher3
- Sep 20, 2008
My son was 4 wheelin and dropped off in a water hole and the engine stalled. When he tried to crank it nothing happened, only clicked. After he pulled it home I raised the hood and smelled burned wires and found the ground from the battery to the radiator support was gone. The flat cable from the fire wall to the block was burned where it crossed other things but it is ok. I found that the big ground to the starter was broken off so I figured this caused the problem. Well I fixed it and the ground from the battery and nothing but a click. Took the stater off and it will spin when hooked directly to battery with jumper cables. Put it back and still nothing but a big click at the selonoid. This may be bad. I put a socket and ratchet on the pulley on the crank and it will not turn over at all. Has something else failed and ruined the engine. It appears to be locked up. I have not yet taken the plugs out and tried it. Any ideas? Someone said Cam Position Synch. may have sheared and locked it up. Could this be hydrolocking and what can I do if it is?
Speedy
Speedy
