306coupe
- May 10, 2008
I saw the sticky at top but I still have a couple questions. I have a 91 ranger I'm wanting to put some 17" mustang bullitt wheels on. The rears go on fine but on the fronts I'm having to use a spacer. Here's my problem. With the spacer the wheel studs are a little bit shorter than I like, I don't have much thread for the lugs to hold onto. I'm scared if I drive it like this I will break a couple studs off if I make a sharp turn or something. I see that moroso makes 3" studs but it warns not to use with wheel spacers. Just wanted to know if anybody else is running bullitts and if you are using the stock studs or what.
