- Sep 23, 2004
- Automatic
full hydro is when you start to break things cuz you cant get a feel in the wheel. plus its not street legal and a horrible idea for the road. if it never sees the road then you will be ok. if you get full hydro and the motor shuts down while your driving, you wont be able to steer. my axle was set up for hydro when i got it but i cut everything away.
Don't just regurgitate bits of misinformation that you've read on the internet. Full hydraulic steering can provide as much or more feedback than conventional mechanical steering systems. It's highly dependent on the type of steering control that you use: load reactive or non-load reactive. Most if not all hydrostatic steering controls (commonly referred to as an orbital) have internal check valves to prevent the oil from returning to the reservoir in the event that the pump stops working. This coupled with displacement of the spool inside the unit provides working pressure enough to maintain control of the vehicle in the event that the engine dies...
I don't really know what I want to do with it. It won't be so big that I couldn't drive it on the street, and I did design it with road manners in mind. I'd trailer it 90% of the time at least, but it would be cool to drive it on occasion.john do you plan to drive your truck on the street besides around the block or something like that
hydro assist is legal in Mn to run on the road they use it with large rigs full hydro is not legal
I've been researching this project for 8 years. I've found numerous "kits" that will bolt on and let you run leaf springs, but that's not at all what I was looking for. I've never been known for buying parts and just bolting them on, I wasn't about to start doing that just because it was 'easier'.just throwing in my .02.
we did a SAS on my buddies 94 GMC using leafs. it was an easy way to do a SAS and resulted in tons of lift. As far as driving on the road, we are from MA where the local and state cops dont like lifted trucks. With the swap and using 6" lift leafs from an earlier model chevy he ran 40" TSLs with alot of room. he drove for a week and than the cops pulled him over and told him that if they saw it on the road again they would tow it.
I'm also not really looking for a huge amount of lift out of this truck, it's just turning out to be that way. I can always pull the 3" body lift to drop it down if I need to. Thanks for the heads up though.
sickness
