Bucket Seat,,help..
DRAGGINASS
TALLAHASSEE, FL
i really want to put a set of bucket seat in my 93 reg cab ranger.. but i was woundering if anyone knows what kind off bucket seats will bolt right in with no mods at all?? if theres any that will..or with mods..what does it take to bolt them in..thanks alot...zeke
You have a 60/40 or a bench? If it's a 60/40 just cut it. I did it and it's very easy!
Just remember with a 60/40, you already have one true bucket. The other can be made into a bucket, but it's just easier to find a bucket from a like ranger, or 1st gen explorer (non power). If you have a bench you are going to need the tracks from either donor vehicle as well. Cheap at U-Pull-its..
I just went to the junk yard and found a passanger seat from a ranger like mine and bolted it right in where the 60 bucket and bench was i think i gave like 20 bucks at the junk yard for the seat. best mod ive done had to make room for the altas:headbang::icon_hornsup::3gears:
well i windin up just cuttin the middle part off....an it worked gr8...now all i need is 2 get the right tool to take the console off...thanks everyone...
post up some pics.. i wouldn't mind doing this eventually to put a center console in
also, i think i have a 60/40... idk really lol, so there's another reason for you to put up pictures hahaha.
What are you guys doing with the seatbelt on the drivers seat? It has a bracket that bolts to the frame that supports the middle seat cushion. If you cut that off, the seatbelt is only hooked to the rail on the floor right? I cut my seat but havent cut the frame yet. Any ideas?
Eric
yea the seat belt is bolted in 2 the floor.,,it was realy easy 2 cut the seat an frame..an i only used a hack saw...
im gonna try an post pics but i never did b4...so give me a min...
an you have a 60/40 if the seat splits right by the pass seat..
