BroncoII springs to an Explorer?
JoseBronco
The BroncoII Superlift 4" leaf springs can work on an Explorer??? Other than spring under axle configuration, can be bolted on it and run ok?
Thankyou
They should fit fine if you turn the centerpins over. You'll probably only get about 2" lift out of them though (Explorer springs have a bit more arch to them from the factory).
Actually explorers get their lift from the sprngs being mounted directly under the frame rail instead of NEXT to the frame rail like on a Ranger
Bronco2s use different mounts that mount the springs lower.
AD
