bronco2 and ranger leaf springs
vince87ranger
woodland, IN
Ok so doing a little bench racing tonight at my buddies and we got to talking about my sagging ranger. It needs new springs in the rear no way around it. A few months ago I got a b2 with a similar lift to my truck but the rear isint using blocks. It's all spring. I scraped the rotten body on with plans for the frame but that's another story. my question is will the b2 springs fit a ranger? All my searches for new ones is saying no but is that just because of the weight diffrent in the rear or am I missing something else?
Since I know Explorer springs have been used in both B2's and Rangers, I'd say it should work just fine..
If you're worried about it, measure the width of both springs, the length (Along the surface. Use a string), and the eye bolt size of both. They should be very, very close..
BII springs will fit, but I don't believe BII's used blocks from the factory so it might not help your situation...
Wait! After reading this again, is the OP talking about stock springs from a B2 or lift springs? Either way they should fit. IDK about the height though..
My ranger is stock leafs with added on helpers and about 5in of block. It still sags more than the front. The b2 frame has I think a 6in lift kit that's got lift springs in the rear, no blocks. It looks to me like the springs will be a direct swap
Well, you seem to know what you're doing. Swap 'em and take pics..
