bronco wont start
chainge11
clinton, tn
just put new heads and gaskets on, put timing back in same spot could not get started finely after moving dist. around it started ran rough but ran. now we are trying to start and we get nothing but the lights coming on but not cranking, replaced switch and solinoid, fuse is ok, why will it not crank with the key, it will if we jump it over at the solinoid already burnt 2 up doing that. please help if you can.
no crank
Neutral safety switch...if auto and if stick and has a clutch pedal lock out switch...ignition switch...solenoid not getting current did you check..check harness...
Welcome to TRS :)
If you have a Starter RELAY on the inner fender, aka starter solenoid, it should have a smaller wire on a smaller stud, stud is labelled "S"
"I" stud, if there is one, is no longer used.
When thae "S" stud gets 12volts the starter relay will close and starter motor will activate, key on or off won't matter so BE CAREFUL.
So just use a short wire from battery positive to that small stud and you won't "burn out" relays(solenoids).
The wire at that stud is usually a red/blue stripe wire, it comes from a Neutral Safety switch as said above.
Clutch pedal switch on manual trans
Transmission switch on automatic
When you turn the key to START, 12volts is sent to Neutral switch, if this switch is CLOSED then that 12volts goes on to the starter relay's "S" stud, which closes that relay and starter motor activates
