- Dec 27, 2020
- Georgia
- Automatic
- Tire Size
- 235/75 R15
I recently started my 87 b2 for the first time after i swapped in a 302 w a holley 4bbl and a summit hei style distributor. I havent set up the neutral safety switch so i jumped the starter via the solenoid. After i had broken in my cam, i let the engine die as i hadnt dialed in the carb yet. When i went to start it again i had no power anywhere in the truck. No red battery light, no headlights, no ignition or fuel pump, nothing. It cranked by jumping the solenoid but ofc didnt start. I have checked the fusible links by the solenoid and the 2 on top of the pass side fender liner. Also checked the two yellow wires at the ignition switch and no power there. I am confused. Any help is appreciated!
UPDATE: SOLVED: I am dumb. I found one of the wires at the solenoid had a bad connection. It had been stretched out so it was startin to tear and get really corroded. Shouldve been hpt at all times but only had like 6.5V. Spliced in a new section of wire w a new ring terminal for now but will be picking up a less used wiring harness at the JY next time i go.
