Bronco II coil spacer?
tomahawk350
Solid Axle Swap
Johnstown, PA
2.9 V6
i've read all about using coil spacers on Ranger to gain 1.5-2" of lift. Has anyone done this on a Bronco II? If so what did you do to lift the back? Any negative handling side effects?
my '89 has good coils up front and i think ford spacers are the way to go... maybe explorer leafs in the rear...
Ranger/Bronco II..all the same.
You'll need an alignment afterwords, as your tires will be sitting lika this \ /
I like the washer method. Cheap and easy
Leafs or shackles in the rear.
I would do the front first and see how much lift you get, and then do the rear, to get them even.
Most RBV's sit a titch lower in the front.
