dccarpenter
- Jan 19, 2019
- Owings, MD
- 2.5 (4 Cylinder)
I picked up a '94 Bronco Eddie Bauer with a nice interior and brand new wheels and tires for the cost of parts. Lights and climate control all work. It was running quite rough, got it running a bit better and then had a local garage look at it as it was misfiring badly under load. He says compression is very bad to none on cylinder #7. I was able to drive it around at 30-40mph and it only shook bad on uphills , etc.. so suprised that it was that bad. It idled like an old car...not terrible though there is a lot of shake to it when viewed. Plug and wire were changed on it.
I've done engine swaps on carburated old trucks but with a bum shoulder and heavy work schedule I don't think I have the time to attempt a EFI motor swap , got quoted $5500 for a Jasper motor + install. I'm guessing a junkyard motor if available will run at least $1600 if put in by the yard.
I could grab one of the $1800 Autozone remans and find a local shade tree guy to put it in, I'd probably be out $3000 by the time it was said and done.
Exterior of the truck is 'ok' other than the cut wheel wells and rusted tailgate, frame and hangers are all in good shape.
Anyone gone the junkyard engine route and had luck? Or a Jasper vs parts store reman experience?
I drive a $400 Ranger around as my only other vehicle so I tend to be very frugal with vehicle expenses, old Broncos do seem to be going up in price though and a rust free frame and spring hanger/coil bucket one isn't a bad starting point. My Ranger's a 4 cylinder regular cab so I do sometimes run across towing tasks or rainy day transport tasks that I wish I had another vehicle for.
