broken rear leaf hangers lift kit time
Mudbogger17
Hedgesville Wv
i am new to domestic trucks as i love my Toyotas but decided it was time for a change after owning my mazda b4000 for only 2weeks the shifter bushing are about gone,clutch went out,and rear spring hangers have both broke at the same time lol so now i think its time to lift it since i will have the springs off anyways anyone have any recommendations??? on brand i have always built my own for my v8 Yotas I have a 1994 mazda b4000 4.0 manual with stock gears like to clear 35's or bigger and what gear ratio would you recommend any help will be appreciated thanks alot
Between doing the lift kit and replacing the rear shackle brackets (I am assuming that is what you are referring to) you will get quite good at removing factory rivets. As for gearing, 4.56 would be a bare minimum, would probably recommend 5.13's. As for a lift, can't go wrong with a 6 inch skyjacker and a little bit of fender trimming. Personally I wouldn't go bigger than 35's, otherwise you will need to look into swapping axles.
hick
