puty72
Last year july 2009 I noticed that my passangers side exhaust manifold had developed a crack in it. I knew that my chances of gettin the old bolts our without breaking where very slim. But anyways i tryed and broked just about every bolt. With the new exhaust manifold sittin there that i paid $80 for i figured i had to find a way to get it on because i didnt have the money to get the bolts drilled out. My buddy and I came up with an idea of using 3 small C clamps on the top to pull it together and hope the remain parts of the bottom bolts will hold the manifold close enough to the head without leaks. I went to lowes and bought 3 three inch c clamps. came out to be $15 (could be cheaper elsewhere). I then cut the flange of the bottom of the c clamp so it would sit in the hole on the front side of the mounting flange on the cylinder head. (picture below)
Then using a leverage bar i tightened them as tight as a i could without doing damage to the mounting area on the head. The c clamp closest to the front of the motor i cut the handle off and welded a nut on so i could use a wrench due to clearance issues.
It is september 2010 now and the c clamps are still holding up very well. I check them every two weeks or so to make sure they are still tight and suprisingly they are. I dont know if this fix will work for every situation depending on how much of the bolt u broke off or not but it worked for me. In the future i will get the bolts drilled out but for now it works fine.
