Shran
Junk Collector
Solid Axle Swap
Truck of Month
After I got done with my lift, I had my truck in for an alignment. Got it back with a 1.5 degree camber correction bushing. Everything was fine and dandy until the first time I took it wheelin about a week later. When I got back, I noticed that two of the teeth on the new bushing had broken off, and the castle nut on the upper balljoint was like finger tight. Tightened that up, cotter pin back in, figured I'd drive it a bit and see what happened.
Well I took it out again last weekend, had some fun, got it home and all but three or four teeth are gone, all on the portion of the bushing that faces the tire.
I can get some pics if needed... I am stumped as to what could be causing this and how to fix it.
