hutch
i noticed a small coolant leak coming from the bottom of the water pump. i tore it all apart and found that 2 bolts on the bottom that hold the water pump to the block were broken off with none of the bolt sticking out. it looks like the previous owner had put some jb weld or something over the holes to try and stop the leaking but it didn't work. the engine runs a little hot but doesnt overheat but i'd like to fix these 2 bolts so it'll can hold the proper amount of coolant. any suggestions?
