broke vacuum line id
chessman21
1969 f-600hd
on my recently acquired 91 i found a broke vacuum line.. the truck has no overdrive nor does ac compressor engage. can somebody tell what this line goes to from the picture?
Hey Friend, I asked this actually a few weeks ago. I believe it actuates your climate control. From the Tee, the bottom branch should connect to the manifold vacuum accessory port, may be why your A/C doesn't kick on.
Sent from my XT1254 using Tapatalk
Actually that vacuum operates the "Blend door" and the line is included in a bundle that runs into the cab kinda below the evaporator enclosure, that "bundle" also connects to the motor speed resistor module on the outside of the evaporator enclosure
