Today I started to tear down the engine I took out of my turboRanger. It had been bored and the crank turned. It looked good enough to throw a set of rings and bearings in it and put it back together. I was going to put it in a hotrod I'm building. I discovered the block had been brocken and welded. Both of the lower corners of the block where the bell housing bolts up had been brocken and welded back on. It's going on the scrap pile now. At least I've got a good crank to work with.
