rfl
We have the steering column on a '93 Ranger opened up right now to replace the multi-function switch (MFS) and the ignition lock cylinder. The MFS was replaced because the brights would not stay on. More specifically, if you pulled the lever back the brights would come on, but if you pushed them forward they would not. Also, if the headlights are off and the brights switch is forward, the headlights come on (just the headlamps, not the marker lights).
Trying to get this thing back on the road - thinking it is not the MFS. Safe to say that? I want to get the column back together.
Thinking maybe the headlight switch itself is going bad? Is there a relay I am missing?
