brakes
mossyoak03
hampton, VA
have a question. i replaced my front rotors, brakes, and passenger side caliper bc the pistons blew. well now the left front squeaks going at a slow speed. i have cleaned the rotors and made sure everything was tightened and still squeaks. it only does it at a slow speed. when applying brakes if goes away. so ne help is appreciated thanks guys
have you tried scuffing everything up with some emery cloth or light sandpaper? it sounds stupid but if there is a glaze on the pads/rotors, they can start making noise. if you use sandpaper, just be sure to not take off too much material, just want to remove the glazing
Sound like you've got an anti-rattle clip rubbing on the rotor. Check to make sure that they are clear of the rotor
Maybe a little grease on the back of the pad where it touches the caliper
