Brakes for my 1994 B2300
Nater
Bamberg, Germany
I have a new set of rotor sitting in the garage...Here is my problem, they do not have a bearing pressed into it, like the ones currently on the truck. Do I have the wrong rotors? Or do I have to by a bearing to press in? Need some help on this as I need to get the truck reinspected in the next 90 days and I know for a fact that they will fail it for the front brakes.
If the bearing races are in good shape you can knock them out of the old rotor and back into the new one. A big brass punch works or you could buy a set of bearing/seal drivers that are nice to have around.
no..the rubber seal on one of the stock rotors is toast...Problem is looking thru summit, I cannot find new bearings:shok:
The wheel bearing seal?? Any parts store should have those. You should replace them every time you remove them to pack or replace bearings anyway. It's almost impossible to remove them without damaging them.
Rockauto has them for about $6-7. Not sure if they ship to Deutschland.
so new rotors do not have the wheel bearings already in the then? so then all I need are new wheel bearings and seals?
