liveandletdie
- Jan 9, 2010
- Automatic
It seems the brakes can't hold pressure at the moment.
I have checked all of the brakes and they are functional/no air bubbles.
Lines seem good, no leaks.
I have narrowed it down to either the brake booster or the master cylinder.
How can I find out which it is that is not functioning?
Obviously I'd rather not get both....but if that is the only option that that's what I'll do...
Tried to bleed the master cylinder but seems to conitunally not get pressure.
Should I replace the booster first? and then replace the master cylinder afterward if that doesn't work?
