Dann757
I just got my 93 Ranger 2.3 5spd 2wd. 42k orig miles, but a lot of issues from not being used much.
It siezed up the right front caliper on a test drive, really smoked it. I just got new front rotors, calipers and pads and rebuilt both sides, totally cleaned and repacked the bearings.
My brand new (rebuilt) caliper is doing the same thing!!! WTF?? I just blued up my new rotor from the heat and of course I'm freaking out. What the heck could be causing this? I made sure all caliper and mount surfaces were clean and slightly lubed with never-seize. The pads are not binding.
It's a PEP Boys reman caliper, could it be the caliper with a bad phenolic piston in it? I don't want to return it if I'm not sure it's that.
I just pulled the caliper and pads and extended the piston onto a piece of 2x4. It seems bound when I try to push it back in with a c clamp, but then it goes back in. SUX
