Brake pedal not returning fully up (happens after driven for a little while)
1999Mazda Central Florida
5+ Year Member
Michelin LTX M/S P235-75R15
Suggestions welcomed: 1999 Mazda B2500. Checked booster with various tests (check valve working/18"Hg intake manifold/and other suggested tests all passed to verify booster issues.)
It seems to happen after driven for a little while. When cold the pedal goes down about 75% (to floor) with an air sound. Vehicle stops just fine. With truck off and booster expelled of all vacuum
I depressed and held pedal firmly for 15 sec. and pedal does not go down more so I know Master cylinder is holding. Another suspicious thing is when I press brake pedal my clutch pedal also
slightly moves. BTW, I looked at bracket and not cracked. I have to bring the pedal up with my toe to return it back. I'm thinking maybe pedal hinges needs to be lubricated.
I also still need to check pads and shoes. Any suggestions welcomed and much appreciated.
Roger in Mt. Dora, Florida
I would agree with worn pedal bushings. Some dry lube might help.
I was thinking chain saw lube (since it sprays on and dries like grease and does not splatter... we'll see.)
The reason I suggest dry lube is so dust doesnt eventually get in there and accelerate wear on the bushings.
There are lubes that go in wet and leave a film after they dry such as alwaysfloored is suggesting. It doesn't have to be anything special. Chain lube from a bicycle shop will work. Wire rope lube for winch cables will work too. A hardware store might have the latter. There are also some firearm lubricants that do that as well.
and also, you can add a light spring that pulls it that final bit up. i had to do that on my old 97 wrangler because it kept leaving hte pedal down just enough to leave the tail lights on. and when you pulled it back up, it moved like a hair. so i found a spring pack at the local autoparts place and tried a few till i found one that worked and didn't add noticeable resistance to pushing the pedal
Event Coverage
TRS Merch
