brake line issues
Well, on the driver's side you have to put some sort of tee in there because there is three lines to connect...one to the master cylinder, one to the caliper, and one to the passenger side...
38622 is the drivers side line
^^ does it have a provision for the extra line hookup back to the master cylinder as well as the hookup to the right side caliper? Thanks.
That block is removable, i reused it from the stock set up. I can snap you a pic of how I did mine
please do....
Here ya go
Drivers Side:
brake line issues
Passenger Side:
brake line issues
Thanks.....I had no idea the line would screw out of that block....it doesn't look like it will...
No problem, you just have to make up a little adapter line like I did on the driver side to get the brake line to attach to the block.
your the man! im ordering these today, what did you do for the rear?
I am using the stock line still, built a bracket to drop it down from the frame a few inches as there is lots of hardline up there.
