brake issue, need help asap
Cummins_Ranger
Jersey
i have a 94 ranger, having brake issues. had to replace one of the lines going from the master cylinder to the proportioning valve. Im not too sure if this was a prior problem, i think it may have been. Onto the issue, i have front brakes bled both sides no issues. I then went to the rear, driver side has nothing coming out and the passanger side has just a drip coming out. anyone with some insight on where to go or what to replace would be greatly appreciated!! :hail: leaving friday for carlisle and need it fixed by thursday thanks for the help everyone
When you say proportioning valve, could it be the RABS valve? Is it mounted on the driver's side frame? I've seen posts about the RABS valve plugging up and not allowing flow to the rear brakes. Might try removing it and flushing it out with brake cleaner.
