brake hoses
hydrosmith
Lacey, WA
I am in the middle of a front brake job on a 1992 STX SC 4WD and I can't get the brake hoses loose from the fitting on the spring perch. I have tried a #10, #12, 3/8 and 7/16 flare wrenches. The #12 kinda gripped but felt like it started to strip the flats of the nut.
Could it really be a #11? Does such a flare nut wrench size exist?
IIRC it is 7/16. 11MM wrenches do exist, but are rare because 7/16 is so close. Clean them up a bit and work the 7/16 on.
I assume you are doing the front discs...when I did mine (88) I just planned on removing everything and replacing them because they were so rusty. There is like a horeshoe clip that holds it in place on the perch but mine were so bad I couldn't even see how they held on...
Once everything is off it pays to clean it all up and put some rust paint on to help keep them clear of rust...mine were in pretty good shape still when I scraped it...so a little does plenty...
EDIT: I have both 11 mm and 7/16"...when the wrench spins it's best to replace the flex lines...
Do you actually need to disconnect the calipers?
Because this usually isn't necessary to disconnect the metal line from the rubber line
unless you are replacing the rubber hoses...
AD
Heh Heh German cars back to pre-history have used the same wrenches as USA. 11mm is close enough to a 7/16s not to matter Same thing with 14mm and 9/16 These are a world standard of some sort . Also spark plug threads are like that too. I have tried a few flare wrenches and haven't found one yet the didn't spread and slip. Here is my rule of thumb after dealing with brakes for 50 yrs. If you cant shift a brake connection with a half way decent open end , its a goner. Next too I dont try to save the line, just the stuff attached to it. I snip the rusty line off with dikes and use a 6 point socket on the fitting. Every hard line and all the hoses have been replaced. By me. If you have a double flare tool, a tubing cutter and a small file. 40 bucks of tools. Line and fittings are cheap and available. :D
I was able to get the 7/16 wrench on there as you said. It came loose just as I was about let up for fear of stripping it.
Thank you
Thank you all. Yes I was replacing the front hoses due to age, they were looking like they are original to the vehicle and my mushy brake pedal is no more!
11mm is close enough to a 7/16s not to matter Same thing with 14mm and 9/16 These are a world standard of some sort . Also spark plug threads are like that too. I have tried a few flare wrenches and haven't found one yet the didn't spread and slip.:D
1) 9/16 fits on a 14. 14 doesn't fit a 9/16. I have stripped a few stubborn bolts trying it that way.
2) My Snap-On line wrenches don't don't spread at all. You are just buying cheap ones.
Heh heh, my metric bugs needed plenty of wrenching. By the time it was used to back up a 9/16, it fit. I started with 29.95 tool box special from Craftsman about 1968. I'm just a shade tree hack trying to get by. I can't justify buying super duper tools, I use very little. My point was that if the fitting on hard line is frozen in rust like they get after a few decades in the rust belt. Yes with a better wrench ,I could get the nut shifted, Probably be too much for the rusty line and it splits, though. You don't save a lot time if you try to a finesse a tender line. Even if it lasts a bit longer, it's a point of failure. Replace the hard line back to a good point that will take a double flare. Better is a home run. I'm comfortable enough with the process, so I take my time and try to do a good job. :D
From the time when I was 18 and a CHEAP ratchet broke causing me to slip and fall and break a finger bone lengthwise (Yes, really! That was the day I discovered that when an ER doctor says "Awwwww... Neat!!!" you are officially having a BAD DAY....
I decided that my tender body parts are too valuable to waste my money on cheap tools...
I CORRECTLY determined that spending money on better tools rather than on Orthopedic surgeons would actually save me money!!!
Not to mention reducing pain and reduce the tendency to leave blood trails
Though I will say if you go into an Emergency room leaving a blood trail you tend to get led around the line and get quick service...
Other than arriving in an ambulance or being a middle aged man complaining of "chest pain" there is no faster way to "jump" the waiting line...
heh-heh one of my favorite sayings is: hey hon, can you help me fix this hole in my hand.
Was that you that I got ahead of in line? Sorry.....
Actually that depends on the hospital and how good...or bad they are. When I had my heart attack, the nimrods at the local band-aid center put me back in the waiting room for 3 hours before they started running tests. This also after they verified my B/P was 210/180. One quad bypass and pacer implant later? I'm rearing to go!!!!
S-
My wife lov s when I come into the house with a " I think I ****ed up". Usually means a good visit to the ear for us.....
