Brake booster leaking from valve when engine is off
gungfudan
15+ Year Member
⭐Supporting Member
Mississippi
3.0 V6
N/A
Total Drop
N/A
So this is probably a simple fix when I turn the engine off there is hissing coming from the brake booster, but it’s right at the valve. Should I replace both the grommet and the valve? Also, do I need to check anything else? That’s the only place it seems like it is leaking.
Sounds like a simple way to start. Try the grommet.
