bowing coils?
94_Xploder
should I be worried about this?
I've seen worse...
Shimming the lower seat angle a bit would probably straighten it up a bit though (or grind your washer spacer down at an angle slightly).
Probably not. Looks a lot like my coils if not a bit *better*.
Like junkie said a shim will help but I've got 30K miles on bowing coils so you're set...
look like ttb coils.....if so they should be fine.
anything under 250 ppi i would build shim seats with pipe and flange...
they are ttb springs
Im still a little low even with the spacers so I might get some of the aluminum spacers off of ebay and cut it at a angle to correct it on that side
